Hi superbullet can you email me the firmware that you have? because AUMA didn't answer to our mails and i didn't found any firmware to downloadWe were able to get a firmware update from Auma. You need to send the serial number of the MOV that is failing then you can download the files and put it in your flash drive. The problem why it did not work the first time was because the files that I originally had was not really for a firmware update. So, even if it does not boot, it will actually get the update from the flash drive once you insert it (need a reboot to be able to detect).
may i know how you resolve the issue comm lost and MWG error. and you please share the process/ steps. thanksHi did you solve the issue..if it's solved pls let me know how to do
Have you gotten any firmware ?
Good day.
Can somebody help me to find the Updated Firmware of Auma AC 01.2? I tried to ask from Auma but nobody replied.
Greetings,
Do you have any firmware update file for Auma Ac 01.2 type.
My email: [email protected]
Thank you in advance,
hello my friend do you have any firmware update file for AUMA AC 01.2 type ?
please sugest soloution about atteched.
thanks
Asad Ali
[email protected]
thanks
[email protected]
Link for Auma Actuator AC 01.2 firmware v06.08.02hello
my friend do you have any firmware update file for AUMA AC 01.2 type ? if everybody have it please share or send it to me, my Email Address is: [email protected]
thanks
Auma MOV | Control Valves | 5 | |
Modbus RTU control change to hardwired auma actuator | Modbus | 1 | |
Auma AC 01.2 “ IE MWG hall sensor “ fault | Control Valves | 5 | |
| M | Auma Actuators "Blowing Up"? | Instrumentation & Measurement | 4 | |
| V | Auma actuators | Instrumentation & Measurement | 15 |
