Hi List,
I have an application that requires a soldered relay to a board. The relay will energize from a 90VDC armature voltage, the relay auxiliary
contacts rated for 10 Ampere, although the continuos amps probably will be less than 1 Ampere. The other option is an input from a small PLC (the application will not need more than 10 discrete digital I/O)that is able to handle that voltage, which I did not find. I know there is din
mount or panel mount relays that could handle this voltage but they are either to bulky or the cost is to excessive.Prefer either a USA made
product or a product made by a company that has distrubution outlets in the USA.
Thank you in advance,
Amr Elaguizy
PS: the information flow within this group is great, thanks to all .
Amr Elaguizy
