3-Phase Motor Wiring Infographic
Compete wiring diagram guide for 3-wire, 6-wire, 9-wire, and 12-wire three-phase motors used for industrial automation.
Technical Article
January 17, 2024
by David Peterson
3-phase motors are the most common motors used to drive heavy loads in most factory automation settings. These motors can be found with a variety of wiring styles, anywhere between 3 and 12 wires, with 9-wire motors being the most common.
This diagram illustrates the most common ways to connect nearly every kind of three-phase motor, for both high and low voltage.
Figure 1. 3-phase motor wiring diagrams of 3-wire, 6-wire, 9-wire, and 12-wire motors. Click on the image to see a high-res (printable 11x17 size) version.
Interested in content about motors? We have plenty to choose from!
Articles:
- 3-phase Motor Types: Synchronous and Induction Motors
- Understanding Delta Wound Motors for Industrial Applications
- Common Motor Windings and Wiring for Three-Phase Motors
Textbook:
