Surplus Valves: Five Checks Before Re-Commissioning
Repair or replace is a common question facing engineers, but what about the second question: buy new, or buy surplus? Before spending your hard-earned money, here are some ways to verify a solid ROI.
When a machine is down and the replacement valve has a six-week lead time, a surplus or pulled valve on a shelf starts looking like a great answer. And quite often, it is - surplus stock is frequently new old stock, or it was pulled from equipment retired for reasons other than malfunction.
The catch is that a valve can look right on the outside, but still be wrong for the circuit. The body matches, the part number is very similar, and it bolts right up to the old bracket. But then right away, it starts leaking at the port, the coil burns out in a week, or the actuator drifts when the power drops. None of those failures are the fault of the valve. They come from skipping a few simple checks that take about fifteen minutes.
This article walks through those checks for pneumatic and hydraulic solenoid valves, in the order we would perform them on a bench.
Where Does the Process Go Wrong?
Most bad surplus installs start the same way: matching on body style and part number alone. Manufacturers reuse a base part number across many variants, and the suffix provides the really crucial details, such as coil voltage, center position, seal material, and port thread. Two valves that differ only in the last few characters can behave very differently.
The second common mistake is skipping a bench check because the valve "looks new." Valves that sat on a shelf for years can have dried seals, a sticky spool from old varnish, or a coil that was damaged in storage. A valve that has never been tested is an unknown, and it doesn’t matter how pristine the packaging looks.
Five Simple Checks
1. Port Sizes and Thread Types
Start with the ports, because a thread mismatch is the most common leak and the easiest to avoid. Three thread families show up most often on valves in North American plants:
• NPT (National Pipe Taper) is a tapered thread with 60-degree flanks. The diameter increases along the length, so the threads wedge tighter as they are tightened. It seals on the threads themselves, with tape or paste filling the small spiral gap left at the crests and roots.
• SAE straight thread O-ring boss (ORB) uses a straight UN/UNF thread, also 60 degrees. The threads only hold the fitting in place. The seal is an O-ring that is pressed into a chamfer at the port face. A -8 ORB port, for example, is 3/4-16 UNF.
• BSPP (British Standard Pipe Parallel) uses a straight Whitworth-form thread with 55-degree flanks. Like ORB, the threads only hold; the seal is a bonded washer or a soft seal on the port face. Its tapered cousin, BSPT, seals on the threads the way NPT does.
The trap is that some of these are close enough to start by hand. A 1/2-inch NPT fitting and a 1/2-inch BSP fitting both have 14 threads per inch and nearly the same outside diameter. They will thread together for a turn or two and feel right. After that, the 60-degree and 55-degree flanks bind, the threads deform, and the joint leaks no matter how much sealant is used.
Figure 1. Comparing various thread patterns. Image used courtesy of Chupp Industrial
Here are some ways to distinguish various threads before anything is connected:
• A thread pitch gauge. Gauges come in 60-degree and 55-degree sets. Use the one whose leaves sit flat in the threads with no light showing.
• Calipers on the outside diameter. Compare to a thread chart, not to memory.
• A straightedge along the threads. Tapered threads show a gap that opens toward the small end. Straight threads sit flat.
• The port face. A flat, machined spot face with a chamfer at the thread entry usually means an O-ring boss port, not pipe thread.
2. Coil Voltage and Polarity
Read the coil tag before looking for any other electrical spec. It will normally show the voltage, whether the coil is AC or DC (including AC frequency, if applicable), and the wattage. Common voltage values are 12 VDC, 24 VDC, and 120 VAC, but there are others.
AC and DC coils are not interchangeable even when running at the same voltage. An AC coil relies on the current-limiting effect of AC impedance. Put DC across it and the current is limited only by the wire's resistance, so the coil runs hot and can burn out quickly. A DC coil on AC will often buzz, chatter, or fail to pull the spool fully over. If the tag is missing or unreadable, do not guess. Many coils are replaceable on the same valve, and a correct new coil is cheap insurance.
A quick resistance check with a multimeter across the coil terminals catches the most common storage failure: an open coil reads as infinite resistance. Compare a good reading to the manufacturer's figure if it is available.
3. Spring Return, Center Position and Fail-safe State
This is the check that matters most for safety, and it’s the one most often skipped.
For a directional valve, verify what the spool does with no signal. A spring-centered three-position valve returns to its center when both coils are off, and the center condition decides what the actuator does in that state:
• Closed center blocks all ports, so a cylinder holds position (subject to spool leakage).
• Tandem center connects pump to tank and blocks the work ports, unloading the pump while holding the load.
• Float center connects the work ports to tank, so the actuator can move freely.
A two-position valve may be spring-offset, returning to one position when de-energized, or detented, staying wherever it was last shifted. For simple two-way solenoid valves, check whether the valve outlet is normally closed or normally open.
Swapping one center or default state for another can turn a machine that holds its load on power loss into one that drops it. Match the symbol on the tag, or the valve's catalog code, to the original before installing it. If you cannot confirm it, do not install it.
4. Seal Material Versus Working Fluid
Seals are chosen for the fluid and the temperature, and the wrong elastomer fails quietly. As a general guide:
• Nitrile (Buna-N) is the common default for petroleum hydraulic oil and compressed air.
• FKM (Viton) handles higher temperatures and many fluids nitrile does not.
• EPDM suits water, water-glycol, and phosphate-ester fluids, but swells and softens in petroleum oil.
Check the valve's seal code against the fluid it will see. Then look at the seals you can reach. Dry, cracked, or flattened O-rings mean the valve sat too long; swollen, soft or sticky seals usually mean it was exposed to a fluid the seals were not made for. Either way, plan on a seal kit before service.
5. A Basic Bench Test
A bench test does not need a full test stand. For a pneumatic valve, regulated shop air at low pressure is enough. For a hydraulic valve, start at low pressure and stay well under the rating on the tag.
• Shift the valve by hand with the manual override, or energize the coil from a correct supply.
• Listen and feel for leak-by at the exhaust or tank port in each position. Spool valves always have a small amount of internal leakage; poppet valves should seal nearly tight. A steady flow where there should be none is a worn spool or bore.
• Check that it returns. A spring-return valve should snap back every time, with no hesitation. A spool that hangs is often varnish, which may clean up, or scoring, which will not.
• Cycle it a few dozen times. Many sticky valves free up; some get worse.
Figure 2. A surplus gate valve. Image used courtesy of Chupp Industrial
When Should You Walk Away?
Some valves are not worth saving, even when they are the only one on hand. Here are a few major red flags:
• The tag is gone and you cannot identify the voltage, center condition, or seals. Unknowns on a safety-relevant valve are not a reasonable risk.
• The spool or bore is scored, or the valve leaks heavily across positions on the bench.
• There is corrosion inside the ports or water in the body, which suggests it sat outdoors or in a wet circuit.
• The body is cracked, or a port thread is damaged or shows signs of having had the wrong fitting forced into it.
• The fail-safe state does not match the original and the machine depends on it.
• The rebuild costs more than the valve is worth. Seal kits, a new coil, and the labor to fit them add up, and at some point a new valve is the better repair.
A surplus valve that passes these checks is usually a sound repair, and it can save days of downtime. One that has not been checked is a guess.
