Barg vs Bara: Understanding Absolute and Gauge Pressure
A common difference of terms arises when referring to air or pneumatic pressure, and those are gauge (BarG) pressure and absolute (BarA) pressure. Both can accurately describe a system, but when performing calculations and tests, it’s important to distinguish the difference.
Fluid systems rely on power transmitted through a gas or liquid to accomplish a task. One of the most important quantities relating to any fluid system is pressure. In technical terms, pressure is the force applied over a surface with a certain area. That area might be the inside walls of a pipe or hose, or the rubber seal inside a directional control valve, or the face of a piston inside a cylinder or actuator.
In a gas system (usually air), the pressures are fairly low since gasses can more easily compress and the molecules simply move closer to each other as energy is applied. Because the pressure inside an air system is relatively much lower than for incompressible fluids (hydraulics), being usually no more than a couple hundred psi, slight deviations of 10 or 20 psi can pose a significant challenge to proper operation, and understanding measurements is absolutely essential.
Bara vs. Barg
When we look at any air-powered system, we must choose to either ignore the fact that there is already air pressure all around us, or we need to include this pressure in our measurement.
Drawing on this assumption, absolute pressure includes the surrounding ambient pressure PLUS any additional pressure supplied by a compressor or system change. Gauge pressure, on the other hand, ignores the pressure from the surrounding environment, measuring only on the pressure supplied by a compressor and external influences like volume and temperature.
Absolute Pressure - bara, psia
If your work is being performed anywhere on earth, you probably have air all around your pneumatic components. You probably also have a compressor drawing in the air from the outside and storing it in a tank of compressed air.
If the tank is ‘empty,’ that’s not really true — it just has the normal amount of outside air inside it. It would not be accurate to say that the air pressure is zero inside an empty tank. Rather, you would say it is equal to whatever is around it.
This ambient outside pressure is called ‘one atmosphere’ of pressure. Depending on the manufacturing origin of the equipment, it might be stated in pounds per square inch (psi), or Newtons per square meter called Pascals, although these are tiny units, so it’s much more common to see thousands of Pascals, or kPa.
Sometimes other units are used, such as Bar or millimeters of Mercury originating from meteorological atmospheric data measurements. Here is a convenient rough comparison just for mental reference:
1 atmosphere = 14.7 psi = 101,000 Pa = 101 kPa = 1 bar = 760 mmHg
I wouldn’t recommend memorizing these since plenty of online calculators are available and almost all datasheets list both psi and kPa, the two most commonly used.
Absolute pressure is the resulting force applied to the inside of the system from the standard atmosphere plus any additional pressure from sources like a compressor or a temperature increase.
Even though it’s the most realistic value of the pressure in the system, it’s not the one used in most measured values.
Gauge Pressure - barg, psig
Pneumatic systems exist for one reason: to get things to move. Motion requires pushing against a load with more force than that which is fighting back. A pneumatic system is pushing on cylinders which always have an atmosphere of pressure outside pushing back. So you will always have to press with at least 14.7 psi plus an additional amount to get something to move.
Figure 1. A typical solenoid valve showing the acceptable pressure allowance of the valve. It shows between 0.15 and 0.8 MPa (mega pascals) which converts to between 22 and 115 psi, which is the allowable gauge pressure in a system that properly uses this valve.
If we are interested in the additional pressure we need to overcome the atmosphere, this is the most commonly used value. We design the gauges to show only the additional pressure above what the atmosphere is already providing. If the gauge shows 15 psi, it means 15 psi more than the atmosphere on the outside.
Mathematically, we could say that absolute pressure is always a higher value than gauge pressure, by exactly one atmosphere.
Abs Pressure = Gauge Pressure + 1 atmosphere
It’s usually safe to assume 14.7 psi or 101 kPa for that one atmosphere, but for very precise measurements, the local ambient pressure from weather patterns and altitude can change the atmospheric pressure.
Since the atmospheric pressure will always be there on both the inside and outside of the system, it’s the difference between the two that causes the air to move through the system and fill the cylinders, and eventually, go to the exhaust ports.
Datasheets will always list values and operating parameters as that difference, or gauge pressure. If a datasheet or parameter is ever meant to be absolute pressure, it will be stated, but this would be extremely rare.
Conveniently, pressure gauges are also calibrated to show gauge and not absolute values. If you turn off the compressor and open a valve to exhaust all the air, eventually it will read 0 psi. If it were showing absolute, it should display 14.7 psi.
Representation as an Electrical System
If an air system is represented like an electrical circuit, then air will flow when a path is established between a high pressure and a low pressure area. This is similar to current flowing when a path is established between +V and common ground.
Within an air system, the ‘common ground’ is the ambient air outside the compressor. If there is a higher pressure inside an airline, and a path is opened, the air will flow, and work will be accomplished.
If you said a control voltage system has 24 volts, it is referenced to the common ground of the power supply, not to the ultimate earth ground. Likewise, an air system pressure will always be referenced to the ambient air, not to the ultimate perfect vacuum.
Usually, there is no connection between a DC power supply and earth ground, so there would never be a case where current would flow. Similarly, there is no path between your pneumatic system and some perfect vacuum chamber nearby, so a reference to a vacuum would be not only confusing but pointless. Of course, we want to represent information as accurately and simply as possible to accomplish a task.
Reviewing the Differences Between BarG and BarA
Absolute pressure is the result of air molecules being forced into a particular area. The pressure value is compared to a perfect vacuum where no air molecules exist at all. It is a more technically correct value, but not useful to the industry since the ambient air is never a perfect vacuum.
Gauge pressure is the pressure inside a system compared to the atmosphere outside the system. It’s a more useful measurement, but also more prone to tiny errors since the ambient pressure can change day-to-day but pressure gauges are not calibrated to these tiny changes.
For nearly every datasheet value and gauge you will ever see, it’s the gauge pressure that is the value being used, unless clearly stated to the contrary.
If you ever need to convert between the two, start with the gauge pressure, add one atmosphere and the result is the absolute pressure.
Need more info about pressure, flow, and fluid systems? We've got you covered!
- Back to the Basics: Pressure Units and Measurements
- Types of Pressure Measurements
- Measuring Flow Rate: An Introduction to Flow Gauges
- Info Byte: Definition of Pressure and Flow in Fluid Systems
It would be better to state that the absolute pressure is equal to the gauge pressure + atmospheric pressure at the site.
There are many industrial plants in eleveted site
There are many industrial facilities at locations elevated above sea level where the atmospheric pressure is significantly less than 101.325 kPaa. The error in all types of calculations involving gases can be serious.
