Electricity and Electronics
Three Phase AC Circuits
10 questions
Page 1 of M03d478b72a271d2b450124b08e12daad2 0 of 10 answers revealed (0%)
  • Question 1 of 10
    Suppose you need to design a three-phase electric heater to dissipate 15 kW of heat when powered by 480 VAC. Your options are to build a delta-connected heater array or a wye-connected heater array:
    Calculate the proper resistance value for each array, to achieve the desired heat output:
    $R_{delta}$ =
    $R_{wye}$ =
    Reveal answer
  • Question 2 of 10
    A three-phase electric motor operating at a line voltage of 4160 VAC (RMS) draws 27.5 A of current (RMS) through each of its lines. Calculate the amount of apparent power consumed by this motor in both kVA electrical and HP mechanical units.
    Reveal answer
  • Question 3 of 10
    Suppose the current through each of the ammeters is 2.81 amps, and the ratio of each current transformer is 100:5. Calculate the horsepower output of this AC motor, assuming a power factor of 1 and an efficiency of 88%
    $P$ =
    Reveal answer
