Electricity and Electronics
Meter and Instrument Usage
9 questions
Page 1 of M03d478b72a271d2b450124b08e12daad2 0 of 9 answers revealed (0%)
  • Question 1 of 9
    Multimeter
    Using the manual-ranging meter image above, select the proper measurement point for verifying 24 vDC signals for a sensor.
    Reveal answer
  • Question 2 of 9
    Multimeter
    Using the manual-ranging meter image above, select the proper measurement point for verifying 120 vAC line voltage to a controller power supply.
    Reveal answer
  • Question 3 of 9
    Multimeter
    A photo sensor datasheet states that the sourcing current output is <250 mA.
    1. What is the proper dial setting to measure the current output of the sensor if the sensor is energized?
    2. If the sensor is de-energized, what is the proper dial setting for measurement?
    Reveal answer
