Electricity and Electronics
Transformer Circuit Calculations
12 questions
Page 1 of M03d478b72a271d2b450124b08e12daad2 0 of 12 answers revealed (0%)
  • Question 1 of 12
    If an ‘isolation transformer’ (a transformer with the same number of turns in the primary and secondary coils) is connected between an AC source and an AC load, we will measure the same voltage and the same current at both source and load terminals:
    If we calculate power output by the source and power dissipated by the load, the value is the same: 420 Watts ($P = I \cdot V$).
    Now suppose we analyze a circuit containing a ‘step-up transformer’ (one with more turns of wire in the secondary coil than in the primary coil). With a step-up transformer, the load voltage will be greater than the supply voltage. In this example, I show a step-up transformer with a 1:2 step ratio:
    Assuming the load resistance is completely different from the first (isolation transformer) circuit, what can you deduce about the load current and the power (both source and load) in this circuit? Is the load current less than the source current? Is the load current greater than the source current? Is the load power greater than the source power? Explain your answers.
    Reveal answer
  • Question 2 of 12
    Industrial control power transformers are used to step down 480 or 240 volts to a level more acceptable for relay control circuitry: usually 120 volts. Some control power transformers are built with multiple primary windings, to facilitate connection to either a 480 volt or 240 volt AC power source:
    Such transformers are usually advertised as having “240 $\times$ 480” primary windings, the “$\times$” symbol representing two independent windings with four connection points (H1 through H4).
    Show the connections on the four “H” terminals necessary for 240 volt operation, and also for 480 volt operation, on the following illustrations:
    Reveal answer
  • Question 3 of 12
    Calculate all listed values for this transformer circuit:
    {\bullet} $V_{primary} = $
    {\bullet} $V_{secondary} = $
    {\bullet} $I_{primary} = $
    {\bullet} $I_{secondary} = $
    Explain whether this is a step-up, step-down, or isolation transformer, and also explain what distinguishes the “primary” winding from the “secondary” winding in any transformer.
    Reveal answer
  • M
    msakho7 February 07, 2021
    It will be very useful if you show the formulas or how you got the answers. Thank you
