Instrumentation and Process Control
Troubleshooting Problems in Control Systems
22 questions
Page 1 of M03d478b72a271d2b450124b08e12daad2 0 of 22 answers revealed (0%)
  • Question 1 of 22
    In this process, two chemical streams are mixed together in a reactor vessel. The ensuing chemical reaction is exothermic (heat-producing) and must be cooled by a water cooling system to prevent overheating of the vessel and piping. A temperature transmitter (TT) senses the reaction product temperature and sends a 4-20 mA signal to a temperature indicating controller (TIC). The controller then sends a 4-20 mA control signal to the temperature valve (TV) to throttle cooling water flow:
    Suppose something fails in the control valve mechanism to make it incapable of opening further than 80
    Describe in detail the effect this fault will have on the performance of the cooling system.
    Reveal answer
  • Question 2 of 22
    A very useful technique for testing process control loop response is to subject it to a “step-change” in controller output. In other words, the process is perturbed (the highly technical term for this is “bumped”) and the results recorded to learn more about its characteristics.
    What practical concerns might surround “bumping” a process such as this? Remember, the process variable (PV) is a real physical measurement such as pressure, level, flow, temperature, pH, or any number of quantities. What precautions should you take prior to perturbing a process to check its response?
    Reveal answer
  • Question 3 of 22
    Inspecting the trends of PV and SP on a process chart recorder, you notice the poor quality of control:
    The “wandering” of the process variable (PV) around setpoint may be due to excessive action on the part of the controller, or it may be due to load fluctuations in the process itself. In other words, the instability may be the fault of the controller reacting too aggressively, or it may be that the controller is not working aggressively enough to counter changes in process load.
    Identify a simple method to determine which scenario is true. Hint: the way to check is as simple as pushing a single button, in most cases.
    Reveal answer
